February 26, 2019, 16:28 |
Issue with Helmholtz (Hodge) decomposition
Greetings,
I am doing decaying compressible homogeneous isotropic turbulence. I need Helmholtz decomposition to separate the solenoidal and dilatational velocity fields. This is the decomposition I am following (according to Wikipedia) where A is a vector field, and Phi is a scalar field. I wrote my own code in MATLAB. Here is a pseudo-code for solving the Poisson equation resulting from the Helmholtz decomposition Here, kx, ky, kz are wave numbers in each direction. Also, I use 4th-order difference for evaluating gradient and divergence: central difference for interior grid points, one-sided difference for boundary points. I apply the code to the solution of the turbulence. The turbulence is solved with 4th-order DRP in space and 4th-order RK in time. Apparently, the solenoidal velocity field is equal to , and the dilatational velocity field is equal to . However, when I compute the divergence of the solenoidal velocity field in order to verify my code, it doesn't return zero divergence; instead, I have maximum divergence around 1.4, average divergence in the domain is around 1.13e-4, seems like the resulting solenoidal field is not divergence-free. I went over my code over and over again. As far as I could, I can't find any bug. The finite difference for computing the gradient and divergence is verified, it should not be a problem. The spectral method does not look wrong to me. So I am lost. Could anyone provide some hints or suggestions? Or is there any benchmark case that I can use for verifying my code? I tried Taylor-Green vortex, but this is not challenging enough. PS: 1. Is it possible that this error is due to the one-sided difference near the boundaries? 2. Is it possible this error is due the the mixture usage of finite difference and spectral method? Appreciate it! |
February 26, 2019, 17:09 |
Filippo Maria Denaro
Rep Power: 71 |
There are lot of hidden issues when you start from the HH decomposition in continuous form and then use it after a discretization. The discrete operators must be congruent and a specific setting of the BCs is required. First of all, I suggest to use standard second order derivative and write the Div Grad operator in discrete form. More details can be found in my paper here https://www.researchgate.net/publica...ary_conditions |
compressible turbulence, helmholtz decomposition |
Issue on zeroGradient BC for system rotation | magnushaese | OpenFOAM Running, Solving & CFD | 2 | January 28, 2022 13:43 |
rhoCentralFoam inviscid airfoil issue (Foam::error::printStack(Foam::Ostream&) at ??) | kmkb21 | OpenFOAM Running, Solving & CFD | 1 | March 1, 2018 01:07 |
Prism Layer - Core Mesh Boundary Issue | InfernoxCJC | STAR-CCM+ | 7 | November 21, 2017 15:46 |
potential flows, helmholtz decomposition and other stuffs | pigna | Main CFD Forum | 1 | October 26, 2017 08:34 |
foamToTecplot360 issue with multiregion solvers | manuc | OpenFOAM Post-Processing | 2 | November 21, 2016 13:51 |
