Try to understand the practice of under-relaxation
Old   February 26, 2019, 02:41
Default Try to understand the practice of under-relaxation
CHEUNG WING KI
as020002 is on a distinguished road
Dear all member,
Greetings guys, I've been reading "An Introduction to Computational Fluid Dynamics: The Finite Volume Method" to get some basic concept of how SIMPLE algorithm works.
I read about the section of under-relaxing the linked coefficients, velocity field from previous iteration. It also says *the under-relaxation is used from the start of the calculation*.
My questions are,
1. Is the under-relaxation applied at the 1st iteration (like applying to coefficient Ap)?
2. Is it necessary that the sum of pressure relaxation factor and velocity relaxation factor equals to 1?
Thanks,
Rick
as020002 is offline   Reply With Quote
Old   February 28, 2019, 03:39
Vignesh Rajendiran
Vignesh2508 is on a distinguished road
1. Yes to my knowledge the under-relaxation is built into the algorithm (you are probably reading SIMPLE algorithm) and applied from the 1st iteration.
2. No it is not necessary to keep it as 1 (It is a good common practice). You can run the simulation even without the under-relaxation factors hoping to get a solution.
Vignesh2508 is offline   Reply With Quote
Old   March 2, 2019, 20:37
CHEUNG WING KI
Thank you very much. I am going to try coding it.
under-relaxation
Lets talk about relaxation factor optimization chriss85 OpenFOAM Running, Solving & CFD 35 June 21, 2019 09:54
best practice for relaxation factor in buoyant driven flow. wanggl OpenFOAM Running, Solving & CFD 3 January 2, 2018 01:36
About equation relaxation chriss85 OpenFOAM Running, Solving & CFD 1 May 2, 2017 19:52
Relaxation and convergence sammi Phoenics 0 March 20, 2008 03:32
Question on adjusting relaxation factor CFD Rookie Main CFD Forum 3 January 26, 2004 14:37
