How to determine Re of a pipe flow (Poiseuille) when pressure inlet and outlet is set |
March 3, 2019, 23:29 |
Js
Rep Power: 13 |
In a 2D pipe flow (Poiseuille flow) Re = U*2R/nu, where R is the radius of the pipe. If I set inlet as U, then I can control the Re by varying viscosity nu.
However, if in the simulation, the pressure inlet and outlet is prescribed, how do I control Re? For example, if I set Re = 100, how should I set nu? nu is supposed to nu = U*2R/Re, however, U is not known a prior as pressure is given in the inlet and outlet. Thanks |
March 4, 2019, 03:06 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
This is a homework you can find in any textbook. Just as hint, write the momentum along the streamwise direction. You will see a relation between the pressure gradient and diffusive term along r. |
poiseuille flow, pressure boundary, reynolds number |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
Pressure drop in pipe flow with Large Eddy Simulation | xerox | FLUENT | 1 | October 16, 2019 08:55 |
Pressure driven flow issues at the inlet of a pipe | CRI_CFD | OpenFOAM Running, Solving & CFD | 1 | May 25, 2016 13:11 |
What BCs to set in Fluent when I know only the static pressure at Inlet and outlet? | nikesh | FLUENT | 0 | January 29, 2015 23:32 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
