Instantaneous Flow Field Images Does Not Change in Time |
April 27, 2019, 07:57 |
I am simulating flow (Re = 525) in a channel that it's upper wall is grooved, it's length is 1.2m and the gap between upper and lower walls is 2.32cm. I made channel width 2.5mm and applied periodic boundary conditions in spanwise directions. Almost 5M hexa mesh was used for this geometry. LES (with dynamic stress) was employed for turbulence modeling. Time step size was equal to 0.0001. My purpose in using LES was to see the change of the instantaneous flow field in time but obtained the same flow field data at every instant. Also, I monitored velocity data at different points and it stopped to change remained constant after a while. Can you give me some advice? What do you think he problem is? Last edited by CaptainCombo; April 29, 2019 at 02:12. |
instantaneous velocity, large eddy simulation., les |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
