Cylinder pressure correct but Heat release rate very high
Old   April 30, 2019, 05:00
Default Cylinder pressure correct but Heat release rate very high
Pradeep
pradeep6890 is on a distinguished road
I modelled a closed cycle diesel combustion in Converge to validate experimental values where I found the pressure to be matching but the heat release rate have double the values. how to reduce the values of HRR?
also is J/time same as J/CA?
thank you in advance
pradeep6890 is offline   Reply With Quote
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 10:00
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
