Unstructured grid connectivity algorithm (elements surrounding face)
Like Tree1Likes
  • 1 Post By t.teschner
Old   May 14, 2019, 15:32
Default Unstructured grid connectivity algorithm (elements surrounding face)
Tom-Robin Teschner
t.teschner is on a distinguished road
I was wondering if anyone has a good source for learning about efficient algorithms that construct the connectivity information that is required in unstructured meshes (specifically, for a face-based solver, how to get the elements that are attached to each side of an element).
I am aware of the book of Lohner (Applied Computational Fluid Dynamics Techniques: An Introduction Based on Finite Element Methods), which talks exactly about that, I just find the explanation a bit brief and would have liked a bit more information.
I found another interesting approach here and here (same author), where the vertices of all faces are stored in some predefined order (here lexicographical) in an array so that entries which have the same vertices must share the same face (and so the element ID can be deduced from those two entries). This, however, still requires two nested loops over the array (in my understanding) and so is probably not as fast as the algorithm described by Lohner.
Apart from those and as stated in the opening, I am interested in algorithms (and preferably some explanations along with them) how to create said face-based data structure. Any sources would be appreciated.
ssh123 likes this.
t.teschner is offline   Reply With Quote
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
unstructured grid wall cells algorithm researcher Main CFD Forum 4 September 10, 2015 10:06
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 22:50
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
