Negative static pressure in pressure contour. |
May 15, 2019, 23:44 |
Jayakrishnan
Rep Power: 7 |
Is there any way to get rid of negative static pressure. I'm doing an analysis of louver blades and the pressure should not go below atm. The only input parameter given is air velocity at 1.7 m/a. I'm using a k episolon model and nothing else. Please help.
May 16, 2019, 02:51 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Well, this is only a sympton that the run will produce numerical oscillations and, likely, an unstable solution. Many reasons could produce this issue. |
May 18, 2019, 01:30 |
Hamid Zoka
Rep Power: 18 |
Hi;
Below atm. pressure is not necessarily a negative one. If inlet pressure to an airfoil (or blade) is near to atmosphere level flow is expected to have below atmosphere values on one side and above atmosphere level on the other side. This is different from negative pressure values. If somewhere in the field negative pressure is seen (i.e. P<0) solution will immediately diverge since it causes negative density and this will propagate throughout the domain. |
May 20, 2019, 04:13 |
Steve
Rep Power: 8 |
You should think about.. reference pressure, static pressure, and B.C Set reference pressure as 0 and Set 1atm for outlet. |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 1 | July 20, 2018 20:05 |
Negative absolute pressure in core vortex | clod | FLUENT | 1 | March 11, 2015 05:33 |
Static vs Total Pressure | Alfonso Ferrandez | FLUENT | 2 | May 23, 2000 08:53 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
