May 4, 2015, 11:37 |
Ideal gas law and incompressible flow
Nick
Rep Power: 15 |
Hi guys,
I've read that when Mach is below 0.3, then the flow is considered incompressible. But in textbooks that look at flow thru a turbo jet, in the compressor or diffuser, nozzle etc although the flow is often subsonic and below Mach 0.3, they use the ideal gas law. My question is: Can the ideal gas law be used when Mach is below 0.3? Why? Isn't the flow supposed to be incompressible? Thanks. |
May 4, 2015, 11:53 |
Michael Prinkey
Rep Power: 25 |
M < 0.3 is a rule of thumb, not a law. Compressibility effects generally scale as M^2. So 0.3^2 makes the error scale as 0.09 if you treat 0.3 Mach flow as incompressible. And, really, this is a statement about local Mach number. You can have flows with an average/freestream Mach number well under 0.3, but have high velocity areas with M>0.3 that end up being important to the overall flow behavior.
May 4, 2015, 12:00 |
Nick
Rep Power: 15 |
Thanks for that. How does one know when to use the ideal gas law then ? How do we know compressibility effects are important?
May 4, 2015, 12:21 |
Filippo Maria Denaro
Rep Power: 71 |
real gas are always compressible in their nature, the "incompressibilty" is only a model used to simplify the set of equations.
But if you assume rho= constant, the continuity equation becomes Div v = 0 and if you consider also homoentalpic condition T= constant that would lead to the ideal law of gas p=const. This conclusion is not correct, pressure gradients in the momentum equation still have sense to ensure a divergence-free velocity field bu you have no law for prescribing a value for the pressure depending on density and temperature. Many researchers use the full compressible model, with the ideal law p=rho*R*T even for low Mach flows. They simply disregard the incompressibility as a simplification and retain the full form of the NS equations. At Mach=0.2-0.3 such formulations work fine, at lower Mach numbers can be necessary to use some pre-conditioning technique. |
May 6, 2015, 20:52 |
Nick
Rep Power: 15 |
Supposing we accurately measured the temperature and density fields around an airfoil in an experiment where the flow Mach number is below 0.3, would the ideal gas law provide the pressure field (the same one as that measured by pressure sensors on the foil for instance)?
May 6, 2015, 21:52 |
Martin Hegedus
Rep Power: 19 |
The assumption of incompressibility does not mean that the flow is actually incompressible. However, the assumption allows for the conservation of mass and momentum to be decoupled from the conservation of energy and the ideal gas equation. So for incompressible flow, one first solves for pressure and velocity and then for temperature and density.
Edit: Incompressibility means that the density changes are small enough the the equations can be decoupled. |
May 7, 2015, 00:07 |
Nick
Rep Power: 15 |
I don't think you could use the incompressible continuity, momentum and energy equations and the ideal gas law together. I think either you assume compressibility whereby you solve the fully N-S equations and gas law OR incompressible flow equations without ideal gas law.
May 7, 2015, 02:11 |
Martin Hegedus
Rep Power: 19 |
There are six unknowns (p, u, v, w, rho, and T) therefore six equations are required. As the Mach number decreases, the compressible and incompressible equations will give nearly the same answer. What the incompressible equations allow for is the solution of p, u, v, and w independently from rho and T since the conservation of mass and momentum are insensitive to changes in density at low Mach numbers.
May 7, 2015, 03:17 |
#9 | |
Rep Power: 71 |
May 7, 2015, 08:58 |
#10 |
Rep Power: 11 |
The Ideal Gas Law as in the Equation of State? Compressibility doesn't dictate its use because density is in the equation itself and therefore compressible effects are taken into account. The IGL relation can be used for any ideal gas regardless of Mach number to relate pressure, volume/density, and temperature.
May 7, 2015, 22:07 |
#11 | |
Nick
Rep Power: 15 |
Sure. What I meant was, if we use an incompressible model, T is found from the energy equation rather than the ideal gas law. Do you agree? |
May 7, 2015, 22:09 |
#12 | |
Nick
Rep Power: 15 |
From what you wrote I understand that if the surface pressure sensors were used to measure the static pressure, it would provide the same values as those found from the ideal gas law. |
May 8, 2015, 03:07 |
#13 | |
Rep Power: 71 |
compressible or incompressible model, T (temperature) is always found from the energy equation... in the incompressible model the energy equation is simply decoupled (apart the buoyancy-driven flow) and can be solved after the continuity and momentum equations are solved. |
May 27, 2019, 14:38 |
ideal gas or constant density
#14 |
Stephen Adeoye
Rep Power: 6 |
i am simulating the flow of super critical c02 through a jet impingement. I am unsure in selecting the models for the gas either to use the ideal gas or constant density.
Density and compressiblity | Mohsin | FLUENT | 7 | June 7, 2015 22:23 |
Incompressible Ideal gas law | Leverkin | FLUENT | 5 | March 5, 2009 16:41 |
Incompressibility - Ideal Gas | selim | CFX | 3 | July 6, 2007 18:10 |
problems simulation ideal gas, divergence in AMG S | Ralf Schmidt | FLUENT | 11 | October 1, 2005 13:21 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 17:49 |
