Simulation time for steady state solution using transient solver |
June 26, 2019, 04:03 |
Sebastian Pelletier
Rep Power: 6 |
This may be a slightly silly question and I`m probably misunderstanding how transient simulations run, but when I am trying to determine what an acceptable real run time for a transient simulation that is meant to find a final steady state solution. Can I base my assumption on the travel time of the fluid through the domain?
For example if the fluid is traveling at 10m/s and the domain is 1m in length is it safe to assume that the approximate length of a single real time period would be .1s? or is the total simulation time not analogous in that way to fluid velocity? If my values of interest (Heat transfer coefficient) appears to have reached steady state would using this estimation be another appropriate check? |
June 26, 2019, 04:08 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
No, you get only an estimation for the convective time in which a fluid particle travels in to the domain. For laminar steady flow, one can assume the non-dimensional time for a steady state to be proportional to the Re number. But in case of a URANS formulation used to get towards the steady RANS solution this is more complex as the physical viscosity is locally changed by the turbulence model. The proper check for the steady state is to use a specific norm on the time derivatives of the variable. Theoretically they should vanish, in practice you can set a proper threshold. |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
time step and iterations in steady state problem using transient solver | jing113cn | FLUENT | 2 | January 15, 2010 03:18 |
