July 1, 2019, 19:45 |
Cylinder in Cross Flow Problem
Rep Power: 7 |
I am trying to run a verification case for a cylinder in cross flow (trying to get Strouhal number = 0.2) and am encountering a consistent error across simulations. There is a subharmonic which shows up in the velocity/pressure and which has a very large contribution. I've attached an image of an FFT and a time history of pressure. The data in the plots is from a point a few diameters downstream of the cylinder.
What could cause this kind of error? Mesh too coarse? Time steps too great? The software I am using is SU2 but I figured that this kind of error may not be software specific so I posted here. Thanks |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Problem to run flow around a cylinder - LES case | valerio galluzzi | OpenFOAM Pre-Processing | 2 | August 29, 2014 05:05 |
Problem to run flow around a cylinder - LES case | valerio galluzzi | OpenFOAM Pre-Processing | 0 | August 26, 2014 07:47 |
simulation of cross flow cylinder | ravigdch | Main CFD Forum | 0 | April 23, 2014 10:13 |
Turbulent steady flow around a circular cylinder | Mirek Kabacinski | FLUENT | 0 | July 23, 2003 18:40 |
