July 4, 2019, 10:28 |
Need Help with meshing a geometry
Rep Power: 6 |
Hello everyone,
I am working on a CFD project where i have to model a combustion process. I found a dissertation and found the meshing data as well but i couldn't create mesh like one shown in dissertation. I am using ANSYS fluent solver. I need help to divide the lower cylinder into 4 parts and to create a square block at the center of cylinder. I have attached an image of the meshing from dissertation. I am a new comer to the CFD world, any help is appreciated. Regards. sdfgh.jpg |
July 4, 2019, 11:00 |
#2 | |
Arjun
Rep Power: 34 |
gambit was creating it. If not then use gmsh. If you can create the mesh in gmsh and wish to convert to fluent format, let me know. I wrote converter for Wildkatze bmsh format, could make converter to fluent too. |
July 4, 2019, 11:05 |
Rep Power: 6 |
July 10, 2019, 13:47 |
Regarding Meshing
Rep Power: 6 |
Hello arjun,
I may have solved the meshing problem that i encountered. When generating CAD model I created separate parts of the complex geometry ( so cylinder was split into 4 outer parts and an inner square as shown in image). So basically I unticked "merge" option in extrude menu of SolidWorks to create separate bodies. 3.PNG
My question- Is this gonna affect my CFD simulation ? And how can i determine the quality of the mesh?? Last edited by Ideapaa; July 11, 2019 at 09:20. |
[snappyHexMesh] FOAM Warnings leading to no geometry, yet OpenFOAM says meshing finished w/o error | edomalley1 | OpenFOAM Meshing & Mesh Conversion | 1 | September 5, 2018 18:30 |
[ICEM] Meshing a fractal geometry in ICEM | andrewmichael | ANSYS Meshing & Geometry | 0 | May 22, 2018 20:17 |
Dynamic Meshing of Simple 2D Geometry | harman79 | FLUENT | 2 | January 17, 2018 06:07 |
Gambit meshing problem to following geometry | ahmadmln | ANSYS Meshing & Geometry | 2 | October 21, 2014 01:49 |
[ANSYS Meshing] Using more than one meshing method on a single 2D geometry | robbierich90 | ANSYS Meshing & Geometry | 0 | October 30, 2011 13:12 |
