Need Help with meshing a geometry
Old   July 4, 2019, 10:28
Default Need Help with meshing a geometry
Ideapaa is on a distinguished road
Hello everyone,
I am working on a CFD project where i have to model a combustion process. I found a dissertation and found the meshing data as well but i couldn't create mesh like one shown in dissertation. I am using ANSYS fluent solver. I need help to divide the lower cylinder into 4 parts and to create a square block at the center of cylinder. I have attached an image of the meshing from dissertation. I am a new comer to the CFD world, any help is appreciated.
Regards.
Ideapaa is offline   Reply With Quote
Old   July 4, 2019, 11:00
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Originally Posted by Ideapaa View Post
Hello everyone,
Regards.
Attachment 70872
gambit was creating it. If not then use gmsh.
If you can create the mesh in gmsh and wish to convert to fluent format, let me know. I wrote converter for Wildkatze bmsh format, could make converter to fluent too.
arjun is offline   Reply With Quote
Old   July 4, 2019, 11:05
Thanks!! I will try to create mesh in gmsh.
Old   July 10, 2019, 13:47
Default Regarding Meshing
Hello arjun,
I may have solved the meshing problem that i encountered. When generating CAD model I created separate parts of the complex geometry ( so cylinder was split into 4 outer parts and an inner square as shown in image). So basically I unticked "merge" option in extrude menu of SolidWorks to create separate bodies.
My question- Is this gonna affect my CFD simulation ?
And how can i determine the quality of the mesh??
[snappyHexMesh] FOAM Warnings leading to no geometry, yet OpenFOAM says meshing finished w/o error edomalley1 OpenFOAM Meshing & Mesh Conversion 1 September 5, 2018 18:30
[ICEM] Meshing a fractal geometry in ICEM andrewmichael ANSYS Meshing & Geometry 0 May 22, 2018 20:17
Dynamic Meshing of Simple 2D Geometry harman79 FLUENT 2 January 17, 2018 06:07
Gambit meshing problem to following geometry ahmadmln ANSYS Meshing & Geometry 2 October 21, 2014 01:49
[ANSYS Meshing] Using more than one meshing method on a single 2D geometry robbierich90 ANSYS Meshing & Geometry 0 October 30, 2011 13:12
