non dimensionalising of Reynolds Stress <u'u'> |
December 17, 2019, 12:40 |
niewiemnic
Rep Power: 8 |
Hallo,
I simulate a channel flow for Re_tau=640. nu ist 2.53e-3 [m^2/s] and Characteristic linear dimension is 1 [m]. Length of channel is 6 [m], Height 2 [m] and width also 2 [m]. So, my u_tau is now 1.62 [m/s] and (u_tau)^2 is 2.624 [m^2/s^2]. What a problem is, my <u'u'> is too high nearby the wall. It is almost yet about 135-140 [m^2/s^2] with flow though time ~500 [s]... Even I divide them by 2.624 [m^2/s^2], it is too big. As you already know, reference datas show me that the highest <u'u'>/(u_tau)^2 is about 7.5-8.0. Or did I understand something wrong? (+) till flow through time ~100[s] the kinematic viscosity was 2.53e-5 [m^2/s] and after that I switched it in 2.53e-3 [m^2/s] |
December 17, 2019, 12:53 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
I have a question, it seems you are solving the dimensional form of the equations, so how do you evaluate that you have Re_tau=640? Are you fixing the driving pressure or the mass constraint? |
December 17, 2019, 13:01 |
niewiemnic
Rep Power: 8 |
Thank you for your answer. Yes, I simulate the problem with OpenFOAM and I use patchMeanVelocityForce with 30.8 [m/s].
Of course the patch for the source is inlet. But for Re_bulk the characteristic linear dimension is 2 [m]. I follow the definition in the website "https://www.rs.tus.ac.jp/~t2lab/db/" and "https://www.openfoam.com/documentation/guides/latest/doc/verification-validation-turbulent-plane-channel-flow.html". Boundary conditions for inlet and outlet are periodic (cyclic in OpenFOAM). |
December 17, 2019, 13:04 |
#4 | |
Rep Power: 71 |
You did not answered to my questions.... |
December 17, 2019, 13:08 |
niewiemnic
Rep Power: 8 |
I am sorry for that I modified the post before you answer me once more. As I wrote I follow the definitions of the two websites.
Re_tau = u_tau*delta/nu delta is half of height of channel, 1 [m]. |
December 17, 2019, 13:20 |
#6 | |
Rep Power: 71 |
The problem is that you don't know u_tau until you have the fully solution. Depending on the setting of the driving force (mass or pressure) you should check a-posteriori the resulting u_tau from the computation of the tau_wall distribution. In https://www.openfoam.com/documentati...nnel-flow.html the u_tau velocity is addressed as "estimated". Hence, I suppose you worked by evaluating u_tau=Re_tau*ni/delta but how this evaluation practically enters in your code? |
December 17, 2019, 13:24 |
niewiemnic
Rep Power: 8 |
Okej, I will check what you answered me. Thank you very much for your comments.
December 17, 2019, 13:32 |
#8 | |
Rep Power: 71 |
The key is that you need to fix a constant pressure gradient in the momentum equation in such a way that it balances the tau_wall computed from Re_tau. Then, the bulk velocity should be evaluated from the solution, that is you have to evaluate the mass flow rate |
"Error in subroutine GETCORE": simulation of an turbine and reynolds stress models | nikn | CFX | 8 | October 30, 2019 15:32 |
[ANSYS Meshing] Error in Workbench "Unable to attach to geometry file" | Jeremie84 | ANSYS Meshing & Geometry | 70 | October 25, 2017 16:03 |
New implemented algebraic Reynolds stress model | volker | OpenFOAM | 13 | October 21, 2013 00:01 |
Eddy Viscosity Models and Reynolds Stress Models | JuPa | CFX | 1 | August 20, 2013 18:56 |
Reynolds Stress Models | Jade M | Main CFD Forum | 0 | April 21, 2010 16:38 |
