December 18, 2019, 09:17 |
Fluent Solver (Convergence Issue)
Hammad
Help/ Suggestions Required!!
I am performing CFD on 3d wing (transonic region) with winglet attached to it. The solution converges when angle of attack is from 0-3 degrees. But when angle is increased to 4 degrees and above, the solution is not converging. Cd and Cl keeps on fluctuating. I am using SA model. |
December 18, 2019, 10:31 |
#2 | |
Rep Power: 11 |
1. Is you mesh refined enough? 2. What solver do you use and what order advection scheme did you choose? If higher than first-order go back to first-order and then see what happen. 3. Does Cd and Cl convergence is not changing within angle change? It's seems strange.. |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 15:44 |
Adjoint solver convergence issue | Alasdair G | FLUENT | 1 | May 6, 2019 11:20 |
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting | arunraj | FLUENT | 0 | June 2, 2016 22:58 |
Convergence issue in Fluent | dibs87jg | FLUENT | 0 | April 20, 2011 04:52 |
