Are there any experimental results for temperature distribution in a square plate? |
February 5, 2020, 00:53 |
Mandeep Shetty
Rep Power: 10 |
Hello, I had recently written a Matlab code for solving the simple 2d heat conduction equation for steady-state temperature distribution in a square plate, using FVM. All the 4 edges of the square plate were set a fixed temperature. I am wondering if there are any experimental results showing steady-state temperature distribution in a square plate, for validation purposes?
Solution Ref: http://tutorial.math.lamar.edu/Class...placesEqn.aspx Last edited by granzer; February 22, 2020 at 03:09. |
February 5, 2020, 02:53 |
Lucky
Rep Power: 66 |
Maybe you can start over and describe your problem again?
A square plate with fixed temperatures... the same temperature? Then the plate is uniform temperature. What is there to even solve and what needs validating? Honestly I have no clue what you're asking for. Initial conditions? Boundary conditions? Dimensions/material to establish a regime? Is this steady heat conduction or transient? If all four sides of the plate are the same temperature then the plate is a uniform temperature and there's nothing to even think about. Unless there is some novelty in your setup, the answer is probably no. No one is going to spend their time testing something that has a known analytical solution. Temperature measurements are hard and expensive. Maybe you should try validating against the analytical solution instead of an experimental one. |
February 5, 2020, 06:17 |
#3 | |
Mandeep Shetty
Rep Power: 10 |
February 5, 2020, 06:37 |
#4 | |
Filippo Maria Denaro
Rep Power: 71 |
The steady state solution satisfies the Laplace equation with the BCs setting you prescribe, you can get many details on a lot of well known textbooks. On the other hand, you can also build your own test-case, just assume the solution T(x,y) as any analytical function that satisfies the Laplace equation, use this function on the boundaries as either Dirichlet or Neumann BCs and then solve numerically. Thus, you can evaluate the discretization error on grids of several sizes. |
February 5, 2020, 11:03 |
Lucky
Rep Power: 66 |
Don't bother looking for any experimental dataset. Just validate it against an analytical solution.
If properties are constant such that the equation is Linear then you can find exact analytical solutions (almost entirely) by hand. The steady state solution follows Laplace's equation. Even the entire transient solution can be solved exactly using eigenfunction expansion, Fourier transform,or Laplace transform approach + superposition. The simple square domain makes these analytical solutions accessible. If non-linear, I even more highly doubt any experimental dataset exists. |
experimental data, heat conduction |
Comparing numerical results to experimental data | Wingman | Main CFD Forum | 0 | April 7, 2017 17:03 |
flow over a plat and study of temperature distribution in plate and flow | Sufyan | FLUENT | 0 | October 16, 2012 03:38 |
Experimental paper for flow over flat plate | Sid | Main CFD Forum | 3 | October 8, 2008 11:45 |
Comparing Experimental and Computational results. | New | Main CFD Forum | 0 | September 27, 2007 12:08 |
Need experimental results on turbulent flow | babyface | Main CFD Forum | 1 | May 22, 2002 12:52 |
