Solidworks Flow simulation lift and drag coefficients
Old   February 28, 2020, 08:42
Exclamation Solidworks Flow simulation lift and drag coefficients
Julieta Ganiele
jganiele is on a distinguished road
Hi all,
I am simulating different airfoil using Flow Simulation, and I cannot obtain values ​​of the lift and drag coefficients consistent with the bibliography.
I was reading several topics, and found that they talked about the importance of the reference system to obtain the correct values, but I do not quite understand how this works. If someone has experience in the subject, it would help me a lot.
Wizard:
- External flow
- Fluid: Air
- Density: 1.225 kg/m3
- velocity in x: 12 m/s
- attack angel: 0º
- airfoil: Naca 4412
- chord leght: 0.145 m
jganiele is offline   Reply With Quote
airfoil, lift and drag, lift coefficent, solidworks flow
Calculation of lift and drag coefficients on airfoil CoolHersheys OpenFOAM Post-Processing 5 September 27, 2021 06:04
How to not overwrite drag and lift coefficients after a simulation Giovanni Trovato FLUENT 1 August 1, 2018 00:31
Estimation of viscous Lift & Drag coefficients from inviscid flow in optimization. freebird Main CFD Forum 1 June 3, 2018 03:40
Lift and Drag coefficients for flow past sphere shashanktiwari619 FLUENT 0 January 27, 2017 13:31
How to compute lift and drag coefficients for flow past a fixed cylinder? antonella.longo@ingv.it Main CFD Forum 2 May 11, 2016 17:26
