Moving piston in a shock tube problem using unsteady, viscous and compressible flows |
February 10, 2020, 02:13 |
Ujjwal
I am trying to simulate a moving (supersonic) piston in a shock tube using 2D unsteady, viscous and compressible flow and I am not able to find a good resource (paper) for the same. How to discretize the Navier Stokes equation and implement the moving boundary conditions?
Note: The velocity of the piston is 900 m/s and the diameter of the shock tube is 8mm. Please help. Thanks! |
compressible fluids, moving piston, unsteady |
Moving piston in a shock tube problem using unsteady, viscous and compressible flows | kujjwal | Mesh Generation & Pre-Processing | 0 | February 10, 2020 01:44 |
Test cases for 2d compressible viscous flows | crazyshock | Main CFD Forum | 2 | October 25, 2017 09:26 |
Newbie to compressible, viscous flow. Advice on approach to problem? | bzz77 | Main CFD Forum | 4 | December 4, 2012 07:59 |
Regarding pressure projection method for unsteady viscous compressible flow | avinash87 | Main CFD Forum | 21 | July 28, 2012 06:55 |
timestep for viscous compressible flows | Ravi | Main CFD Forum | 2 | July 12, 2005 13:51 |
