Define interface between two non conformal meshes
Old   February 27, 2020, 03:57
Default Define interface between two non conformal meshes
Amr Emad Ezzat
Amr Emad Ezzat is on a distinguished road
Hello everyone,
Does anybody have any idea about how to define an interface between non-conformal meshes (e.g Tetra and Hexa) without moving the interface in OpenFOAM?
Thanks in advance!
Amr Emad Ezzat is offline   Reply With Quote
Old   February 27, 2020, 09:35
Mikko
Flowkersma is on a distinguished road
Hi Amr,
If the interfaces are adjacent, you can use arbitrary mesh interpolation (AMI). If the meshes are overlapping then use overset. If you want to make the two meshes conforming, you can either add hanging nodes or a layer of pyramids at the interface.
Best, Mikko
Flowkersma is offline   Reply With Quote
Old   February 27, 2020, 09:39
Amr Emad Ezzat
Hello Mikko,
Perfect. Is this fit the cyclicAMI type or there is another type to be used? knowing that the two sides of the mesh are static and not moving
interface domains, mesh 3d, non conformal interface, openfoam
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 01:44
An odd ERROR mdakbari Fluent UDF and Scheme Programming 7 April 4, 2016 04:30
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 10:19
