March 4, 2020, 22:49 |
Which is the correct Physics?
Vignesh Veeresparan
Rep Power: 6 |
Hello All,
I have an interesting and may be a simple question on fluid flow. Let us assume, case 1 we have cylindrical pipe where the flow enters at inlet pressure P1 and exits at outlet pressure P2 for given length (P1>P2). In case 2, we have same cylindrical pipe with some blockage in middle of the pipe. The only difference is blockage within the pipe. Now, the question is pressure P1 in both case 1 & case 2 will it still remain the same if the pressure P2 is same in both cases. If Yes/No, kindly explain the physics scenario. Might be my question look silly. But I'm looking for proper explanation. |
March 4, 2020, 23:30 |
Lucky
Rep Power: 66 |
That's not the ONLY difference because you haven't considered that there is a flow and this flow interacts with the blockage. In general the difference between P1 and P2 (the pressure drop) is a function of the flow field and vice versa.
You can have the same P2 and find a flow for Case 1 that yields a P1 and a different flow for Case 2 that yields the same P1. Alternatively, if you have nominally the same flowrate and you hold P2 the same for both, then P1 should change to whatever it needs to be to satisfy the flowrate. |
March 4, 2020, 23:50 |
Vignesh Veeresparan
Rep Power: 6 |
Thanks LuckyTran for your explanation. This is what i had in mind.
One more question for better understanding. So, for same P1 and P2 in both cases which one will have higher flow. I hope case 1 will have more flow with lesser resistance. Correct me if I am wrong. |
March 5, 2020, 03:00 |
Filippo Maria Denaro
Rep Power: 71 |
Considering the characteristic theory for compressible Subsonic flows, the inflow will be influenced by the internal flow
Is openfoam code used in other realm of physics ? | EternalSeekerX | Lounge | 1 | April 24, 2017 13:48 |
void correct() in basicChemistryModel | rhythm | OpenFOAM Programming & Development | 1 | December 11, 2015 05:56 |
How do we know ANSYS's simulations are correct? | federernadal | ANSYS | 1 | November 12, 2015 09:10 |
[waves2Foam] Does the surfaceElevation utility give correct results for parallel case? | ashim | OpenFOAM Community Contributions | 1 | July 22, 2015 09:24 |
Is there a way to find a correct "spacing"? | Jordi P. | Main CFD Forum | 2 | August 15, 2013 10:05 |
