[waves2Foam] Does the surfaceElevation utility give correct results for parallel case?
Old   July 22, 2015, 08:40
Default Does the surfaceElevation utility give correct results for parallel case?
Ali
ashim is on a distinguished road
Hello Niels,
Does the surfaceElevation utility give correct results for parallel case? I am using it in foam-extend 3.1. In serial simulation this utility is giving correct results, but in parallel simulation near the processor boundary the results is not correct.
Thank you very much.
Kind regards,
Ali
ashim is offline   Reply With Quote
Old   July 22, 2015, 09:24
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hallo Ali,
This is a known bug:
http://sourceforge.net/p/openfoam-ex...aves2foam/223/
I have not yet found a solution to this, but you could try to change the interpolation routine for the sampling.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
rasInterFoam appears to give erroneous results for “pd”. richard_kenny OpenFOAM Bugs 6 August 2, 2013 17:12
why dynamic mesh method give wrong results? weiyang1980 Main CFD Forum 0 September 22, 2009 21:06
Test Case results for Semi-Cylinder shankar1221989 Main CFD Forum 0 June 24, 2009 06:35
Must periodic oscillation give periodic results? zonexo Main CFD Forum 6 May 13, 2007 15:36
who can give me some case? willams FLUENT 2 July 29, 2001 07:39
