Which transport equation, which scheme, which model???
Old   March 5, 2020, 06:59
Default Which transport equation, which scheme, which model???
Masih
masih.mojarrad is on a distinguished road
Hi all,
My project is related to filling a tank with hydrogen. The inlet mass flow is 1 kg/s and the the tank initially has 1 kg hydrogen inside. So, technically after 5 seconds, the mass inside the tank should reach to 6 kg.
First, I used Peng-Robinson equations and after checking the final result by using integrate variables in paraview I found out the final mass was much less than I expected. Then, I changed the transport equations to perfect gas. In that case, the mass inside the tank reached to 9 kg.
I have tried different schemes including linear, upwind and linearUpwind schemes and I also tried both kEpsilon and kOmeqaSST models but none of them influenced the final result that much.
I am using openfoam 5 and the rhoCentralFoam is the solver. What is the problem do you think and how can i deal with it?
Best regrads,
Masih Mojarrad
masih.mojarrad is offline   Reply With Quote
Adding diffusion term to interFoam transport equation Gearb0x OpenFOAM Programming & Development 3 February 14, 2023 04:16
Solving User-defined Scalar Transport Equation properly meepokman Fluent UDF and Scheme Programming 0 July 10, 2018 07:57
Zero equation Vs k-epsilon model CFD_smukthi Main CFD Forum 1 December 3, 2016 16:57
error message cuteapathy CFX 14 March 20, 2012 06:45
Adding transport equation to radiation model kirankarki OpenFOAM 0 October 26, 2010 16:10
