convergence criterion
Old   June 16, 2000, 09:00
Default convergence criterion
Luca
I am a new phoenics user, can anybody tell me what is the GLOBAL CONVERGENCE CRITERION (default value 10e-4) that is in the NUMERICS menu? I think it is something linked to the residuals but I don't know how it is calculated, does anybody know?
Old   June 16, 2000, 20:06
Default Re: convergence criterion
John C. Chien
(1). Don't try to understand the definition. There is nothing you can do there. (2). When I run a commercial code, I always set these numbers (you are likely to have one for each equation being solved) to 1.0E-08 that is 0.00000001 Then you can set it and forget about it. (2). Use the total number of iterations to control the convergence. Check the variables of interest to you at several locations of interest, and plot the convergence history. (3). The flow convergence (steady state) is non-uniform, at some locations it is fast and at some other locations it is very solw. To reach convergence, you must be able to see flat part of the history plots of the variables vs iteration numbers. (4). Let the computer do the number crunching hard work, and make sure that you have the converged solution. (mesh size and quality always has a great impact on the convergence of the solution) Do not accept the solution unless it is the fully converged solution.
Old   June 18, 2000, 02:43
Duane
Hi Luca,
global convergence USUALLY refers to a volume integration over the entire domain. So for mass conservation it is the sum of all mass flow rates at the boundaries (and source terms) normalized by the inlet mass flow. So 10e-4 is an overall ballance within 0.01%. This is an indication of how well the nonlinear discrete equations have been solved NOT necessarily of the accuracy of the discrete equations in approximating the solution. 1e-4 is typically for industrial work. It is also important to look at the local residuals how well the individual control volume equations have been solved by the nonlinear iterative process.
Good Luck..................Duane
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Force can not converge colopolo CFX 13 October 4, 2011 22:03
convergence criterion Dominique FLUENT 5 November 24, 2006 02:36
Setting convergence criterion Vidya FLUENT 5 August 6, 2006 16:46
