April 2, 2020, 16:52 |
Parameterization Update Problem
Raj
Rep Power: 6 |
Hello guys,
I have a model with a velocity-inlet and outlet. The input parameters are velocity, temperature, and radius. The output parameters are heat flux and shear stress. When I am adding the new design point for the parameter, I am getting the following error "Update failed for the Solution component in 2dfil for Design Point 135. Update Solution Failed" and there is no output result. Please help me or suggest a possible solution to generate new design points. Thank you Raj Last edited by Rajkool; April 2, 2020 at 16:54. Reason: Spelling mistake |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 10 | February 7, 2024 21:50 |
Convergence Problem in Multiphase problem (three phases) | m.uzair | FLUENT | 0 | August 2, 2018 08:23 |
Large problem partitioner | tzy | CFX | 3 | February 7, 2018 17:11 |
Test Case CFL Number Issues with Software Update | JBCFD | SU2 | 3 | July 14, 2017 12:05 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
