Post Results Comparison
Old   April 6, 2020, 04:46
Default Post Results Comparison
RustyCohle is on a distinguished road
Hi folks,
I'm currently meshing a turbocharger volute and I want to compare different meshes with varying parameters (especially prism layer parameters). Now I'm looking for a way to compare my results from steady state simulations. My initial conditions are always the same. I only exchange the volute mesh. My impeller mesh stays untouched. For my steady state simulations I thought about these parameters for comparison:
  • mass flow
  • total pressure loss (over the volute only)
  • flow angle
  • visual comparison like velocity and pressure plots on a plane across the volute
My meshes are generated with ICEM and my simulations are performed with ANSYS CFX.
Now my question would be if you guys think that I should add other tools for comparison or if you have an other idea how to compare my results.
I'm looking forward to your replies. Thanks in advance!
Regards
Rusty Cohle
RustyCohle is offline   Reply With Quote
Comparison of experimental and CFD results for the VA-2 supercritical airfoil Aurélien FLUENT 3 April 24, 2024 10:39
cfd post results imthiyaz FLUENT 0 September 25, 2016 09:49
Fluent vs post engine calculator ? results Ondrej FLUENT 0 July 31, 2014 13:17
[OpenFOAM] Could not post process the results of sprayFoam using paraview balaji ParaView 2 June 14, 2012 23:18
Adding results in CFX 11 post Dimitri CFX 0 February 5, 2008 04:28
