April 29, 2020, 01:39 |
Finding enthalphy for tee junction
dhanik
Rep Power: 6 |
I am simulating tee junction, 2 inlets and 1 outlet, hot inlet temp is 36 c & cold inlet temp is 19 c, hot inlet velocity is 3 m/s and cold inlet velocity is 12m/s
By simulation, I get 2559.11 J/kg enthalpy at an outlet , How to find enthalpy at an outlet by equation Formula is h(mixing)=m(hot)*h(hot)+m(cold)*h(cold)/m(total) How to find h hot and h cold? Material is air Last edited by Dhanik desai; April 29, 2020 at 05:28. |
April 29, 2020, 05:05 |
Lucky
Rep Power: 66 |
You need an equation of state. If you are doing a simulation of some sort, the equation of state is a user setting.
April 29, 2020, 05:28 |
dhanik
Rep Power: 6 |
Hi sir , thanks for reply I want to find h hot and h cold manually
April 29, 2020, 08:58 |
Rep Power: 18 |
You will need to use the equation of state to evaluate the enthalpy by hand. For this you need thermodynamics, but here's a hint. For air at the temperatures you are working with the enthalpy can be expressed to a high degree of accuracy as h = Cp * T, where Cp is the specific heat at constant pressure.
May 1, 2020, 05:53 |
dhanik
Rep Power: 6 |
Thank you, sir, I did it with Cp *delta t where Tref is 298.15K
cfd - post, flow analysis, simulation cfd, thermal analysis |
Meshing junction between wing and nacelle using algebraic extrusion method | zacwhee | Pointwise & Gridgen | 0 | March 23, 2018 00:39 |
[ICEM] mesh T junction with no same diameter | black_hunter | ANSYS Meshing & Geometry | 0 | August 28, 2016 20:52 |
User Junction Box in CFX: Example 1 from the Solver Modeling Guide | gt_moe | CFX | 3 | May 26, 2016 10:40 |
[ICEM] Blocking strategy for sharp angle junction (Pipe) | Daniel_Khazaei | ANSYS Meshing & Geometry | 6 | February 19, 2015 11:31 |
Junction Box | Anil | CFX | 2 | June 27, 2006 10:18 |
