Negative Drag Values for only some surfaces?? Please help |
May 2, 2020, 06:39 |
Rep Power: 6 |
Hi there, my deadline for my senior project is fast approaching and any help would be extremely appreciated right now!
Using Star-CCM I'm modelling an external aerodynamics simulation of a fixed wing UAV (see attached photos). I have run preliminary simulations using the realizable k-epsilon turb model with a target Y+ of 30, all converged nicely. I have separate surface controls for each of my surfaces, and upon running a drag report for each surface I'm getting some as positive and some as negative?? In this case my fan, hinge point and wing/fuselage joint are fine, but the fuselage, H-Tail, V-Tail and Wing all are producing negative results? I think the report is set up correctly. To add to it, upon looking at the y+ in a scalar field I notice there are some missing sections of the geometry in the scene which have not appeared anywhere else. (See Photo) Any ideas please, again any help would be much appreciated. |
negative drag values, star-ccm |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
Airfoil with simpleFoam and kOmegaSST: high drag values? | Tsiolkovsky | OpenFOAM Running, Solving & CFD | 6 | November 21, 2018 05:56 |
Negative Drag in Natural Convection | Ashwini | FLUENT | 0 | July 13, 2018 05:26 |
Negative Drag on Airfoil | jasonbot | FLUENT | 0 | October 1, 2013 06:23 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
