How to find flow over the cylinder at different time |
Prudvi
Rep Power: 6 ![]() |
I am working flow over the cylinder, using 2D VOF transient and using variable time step...I want to know water flow over the cylinder at different time seconds.....can someone suggest...Attached image for your understanding...
Thanks in advance.... flow at diff times.JPG |
#2 | |
Filippo Maria Denaro
Rep Power: 71 ![]() ![]() ![]() |
What is your problem specifically? You need first the solution forgets the arbitrary initial condition, then you can save the data in time at a specified interval |
Prudvi
Yogesh Nalam
Rep Power: 13 ![]() |
1. Create an Iso-surface with scalar as your required phase.
2. Create a report of sum of area for the iso-surface 3. Monitor the report to get the are wet by the fluid Hope this helps ? |
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores | puneet336 | OpenFOAM Running, Solving & CFD | 11 | April 7, 2019 00:58 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
How to export time series of variables for one point? | mary mor | OpenFOAM Post-Processing | 8 | July 19, 2017 10:54 |
Unstructrued O-type Mesh of a cylinder with icoFoam | kindle | OpenFOAM Running, Solving & CFD | 1 | December 2, 2016 11:45 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
