Generate Fluid Volumes For Axial Turbine Blades |
October 22, 2019, 00:40 |
Thanushka
Rep Power: 6 |
I have created stator blades and rotor blades by using coordinates and used SolidWorks. However, I tried to create fluid volumes for those blades, to simulate in CFX and have not achieved yet. I need to generate the following kind of Fluid volume.
Could you please give me some insights on this? |
October 23, 2019, 04:35 |
Rep Power: 12 |
You could use a Workbench setup of Bladegen->TurboGrid->CFX, which might be simpler and quicker. However, Bladegen may not facilitate curve parameterization, at least not conveniently.
October 23, 2019, 20:36 |
Thanushka
Rep Power: 6 |
Thanks, Fresty. I have tried Bladegen. But it doesn't facilitate blade creating from given coordinates.
October 24, 2019, 04:13 |
Rep Power: 12 |
You could import coordinates directly from a .dat file, using data import wizard.
May 16, 2020, 10:09 |
Solution Found
Thanushka
Rep Power: 6 |
axial turbine, blade passage, fluid volume |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
Need to output surface pressure on blades in a vertical axis wind turbine | kmallick | OpenFOAM Post-Processing | 1 | October 21, 2018 23:08 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Error in Two phase (condensation) modeling | adilsyyed | CFX | 15 | June 24, 2015 19:42 |
Y-Grid and turbine blades | Vitali | CFX | 7 | June 22, 2009 06:46 |
