Cross-Sectional Streamlines for an In-compressible Flow Inside Pipe |
May 10, 2020, 16:14 |
Hello Everyone,
I have simulated an incompressible flow inside a pipe using a steady-state RANS model. Inlet boundary conditions are inlet velocity and zero gradient pressure, and at the outlet, I have zero-gradient boundary conditions. Cross-sectional streamlines exactly at the inlet are outward from the centre toward the wall, and slightly after inlet, they are changing direction, and then became inward from the wall toward the centre. This phenomenon appears multiple times along the length of the pipe. (Picture is attached) Does anyone know why this happens? |
May 11, 2020, 03:30 |
Filippo Maria Denaro
Rep Power: 71 |
How do you compute these streamlines? In a plane-section of a 3D flow you have disregarded the third velocity components?
May 11, 2020, 18:42 |
#3 | |
(Ux, the streamwise velocity is disregarded) |
May 12, 2020, 02:52 |
#4 | |
Rep Power: 71 |
However, if you prescribed as inlet an inviscid velocity profile the flow in the section next to the inflow one should show a small radial velocity from the wall towards the center. But if you see that the radial components changes sign that appears as a nunerical oscillation. Check the computed variables not the streamiline to assess the solution is free from spurious oscillations. |
incompressible, pipe, steady state rans, streamlines |
Multiphase flow in a pipe with a CHT | wissal | CFX | 4 | June 12, 2017 12:15 |
Fans inside domain, orthogonal to surrounding stream | simpomann | OpenFOAM Running, Solving & CFD | 0 | July 7, 2014 20:34 |
[snappyHexMesh] No Surface-Layers on pipe with hexagonal cross sectional area | U.Golling | OpenFOAM Meshing & Mesh Conversion | 0 | December 10, 2010 09:08 |
compressible flow through a pipe | rajiv | FLUENT | 0 | April 3, 2010 00:36 |
Aerodynamics of Cross flow fan | Yerram Ravinder | Main CFD Forum | 1 | September 6, 1999 01:07 |
