surfaceFieldValue, sampledSurface, areaAverage at no slip wall, velocity not zero |
September 12, 2020, 10:02 |
Tom Lauriks
Rep Power: 6 |
Hi foamers,
I'm performing an LES of channel flow. My domain is a box, with the boundaries perpendicular to x or z periodic. The boundaries perpendicular to y are walls with a no slip condition. I want to calculate derived variables by extracting data with function objects. I need the average x velocity component, u, over planes parallel to the walls. I need, e.g., u_avg on a plane with y=0 (on the wall) and with y=0.00456 (to calculate the gradient). However, u_avg on the plane on the wall is not zero. I integrated u over the same plane in paraview and this results in zero. I'll paste the code of my function object below. Anyone any ideas what is going on? In the function dict in my controlDict: Code:
planeBottom1 { type surfaceFieldValue; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; writeControl timeStep; writeInterval 10; log true; writeFields false; regionType sampledSurface; name dummy; sampledSurfaceDict { type plane; planeType pointAndNormal; pointAndNormalDict { basePoint (0 0 0); normalVector (0 1 0); } } operation areaAverage; fields ( U ); } The output of this function object: # Region type : sampledSurface dummy # Faces : 2048 # Area : 4.500000e+00 # Time areaAverage(U) 0.0311504 (1.868055e-01 1.709084e-17 -1.899840e-29) 0.224026 (1.045627e-01 -4.220888e-14 -6.870517e-22) 0.905977 (5.695619e-02 3.788209e-10 -2.763147e-16) 1.284177612133 (3.842192e-02 1.437856e-11 -4.871026e-14) |
September 15, 2020, 08:06 |
#2 | |
Tom Lauriks
Rep Power: 6 |
I found a solution to my problem. I specified to interpolate in the sampledSurfaceDict:
The output is now: # Region type : sampledSurface dummy # Faces : 2048 # Area : 4.500000e+00 # Time areaAverage(U) 0.0012 (5.338272e-19 -4.697408e-40 -1.106682e-40) 0.00264 (5.323610e-19 6.582011e-33 -4.653934e-36) 0.004368 (5.306123e-19 -6.219411e-34 -1.794711e-35) This is not what I expected though. I expected the cell values adjacent to the wall to be zero, so I didn't expect to need interpolation there. Is this a bug, or am I missing something? |
September 15, 2020, 17:33 |
Rep Power: 8 |
Since the values are calculated in the cell center, they are not equal to 0.
September 16, 2020, 03:05 |
Tom Lauriks
Rep Power: 6 |
I was assuming that in the finite volume method, there exists only the cell value. And that therefore the value of the boundary condition, is imposed at the cell next to the wall. But it's good to know the boundary condition is imposed at the boundary faces and that the cell values at the boundary cells are still calculated. Thanks for your answer.
areaaverage, noslip, sampledsurface, surfacefieldvalue, zero velocity |
UDF for suction velocity on a wall | ahmed425 | Fluent UDF and Scheme Programming | 0 | November 2, 2017 09:50 |
velocity BC for pourous wall (pressure dependendend darcy law) | StefanW | OpenFOAM Running, Solving & CFD | 1 | May 29, 2017 07:53 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
UDF for slip and moving wall | lichun Dong | FLUENT | 3 | March 26, 2014 04:37 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
