Analysis differences with respect to size
Like Tree3Likes
  • 1 Post By evcelica
  • 1 Post By FMDenaro
  • 1 Post By flotus1
Old   June 22, 2020, 12:00
Default Analysis differences with respect to size
Ozgur
AerospaceEngineer is on a distinguished road
I have a wooden computer. So solving big geometries is nearly impossible. When I scale geometry like 1/10 would that matter or change the results ?
AerospaceEngineer is offline   Reply With Quote
Old   June 22, 2020, 15:18
Erik
evcelica is on a distinguished road
It depends on what you are doing, but scaling the size is not a smart solution.
Geometric Size should not matter for calculation time. It is the # of mesh elements which matters.
AerospaceEngineer likes this.
evcelica is offline   Reply With Quote
Old   June 22, 2020, 17:47
Ozgur
Yes the problem starts after meshing. I have a wooden pc and if my mesh number goes like 2m computer gives me headaches. Solution takes hours and i cant even see if its right or wrong. So I thought i could scale body, give appropriate meshing and solve it in a hour. But it is not ideal, you say.
Old   June 23, 2020, 03:22
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Scaling can be done, provided the Re number is the same. Therefore the computational resolution, required for your case is the same even after scaling.
Several hours of computational time are quite normal...
FMDenaro is offline   Reply With Quote
Old   June 23, 2020, 03:48
Ozgur
So if i rearrenge re number an continue with scaled geometry it is ok. I am trying to solve for a small aircraft. But geometry is too big for pc. Always stops, program freezes etc.
Old   June 23, 2020, 08:24
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
To re-iterate what FMDenaro wrote: scaling the geometry does not achieve anything with regards to computational cost.
If you decreased the geometric size of your model by a factor of 10, you would need to e.g. decrease viscosity by a factor of 10 in order to have the same Reynolds Number. Otherwise, you would change physics, and get absolutely useless results in regards to your original case.
That in turn means your cell size would also have to decrease by a factor of 10 in order to achieve the same resolution.
You can scale the geometric size all you want, it does nothing to reduce computational cost.
FMDenaro likes this.
flotus1 is offline   Reply With Quote
Issues with poor performance in faster CPU gian93 Hardware 9 October 29, 2018 13:34
Bubble size analysis in Fluidized beds Musa FLUENT 1 March 18, 2013 04:01
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
