August 6, 2020, 20:41 |
Mesh independent study when comparing models
dilaw meda
Rep Power: 8 |
Hi. I am doing a numerical study on air jets. i want to compare 3 rans models: K epsilone , rsm and sst k omega. Should i do a mesh independent study for every model then comparing ?. Or i chose one model , i do the mesh study then with the suitable mesh i do simulation with the 2 other models and i compare wich model is better in my case
August 6, 2020, 22:26 |
#2 | |
Rep Power: 14 |
I have never noticed that the model got re-meshed by the software after I changed the turbulence mode, so I would optimize the mesh with one of the modes and run the other two turbulence modes with the same mesh. My feeling is that it will give you more realistic comparative results as well because if you change both the mesh and the turbulence mode you'd never know what is causing the difference (if any). |
August 7, 2020, 09:04 |
#3 | |
dilaw meda
Rep Power: 8 |
August 7, 2020, 11:53 |
Filippo Maria Denaro
Rep Power: 71 |
My opinion is that each test would represent a different study and meaning of the comparison.
One could wonder about the best performance of several softwares and/or turbulent models on the same chosen grid. As well as one could check the statistical solution for "vanishing" grid size (provided that the model allows that). I don't think that a way of doing a comparison excludes the others. |
August 7, 2020, 12:29 |
#5 | |
Rep Power: 14 |
August 13, 2020, 00:52 |
#6 | |
Srykia Konjha
jets, mesh, rans, simulation |
Mesh Independent Study | Concvistador | FLUENT | 0 | May 1, 2015 08:30 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
Mesh sensitivity when using phase change models | BKaus | STAR-CCM+ | 0 | February 28, 2012 20:51 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
