Problem in exporting file from BladeGen to TurboGrid
Like Tree2Likes
  • 1 Post By Dushyant
  • 1 Post By AbdoBedir
Old   January 16, 2020, 13:54
Default Problem in exporting file from BladeGen to TurboGrid
Dushyant Singh
Dushyant is on a distinguished road
I am trying to run simulation on a Radial Turbine Blade created in BladeGen. But when I try to transfer the data in TurboGrid Mesh it gives an error that says " Error Occured while writing .inf file". I tried generating the .inf file in BladeGen but whenever I do so it says that the application has stopped working. The three .curve file are being created but the .inf file seems to have some problem. Please help.
ssmacae likes this.
Dushyant is offline   Reply With Quote
Old   September 24, 2020, 15:11
Default Same issue
Bedir
AbdoBedir is on a distinguished road
I have the same problem, Please if any body found a solution share it.
Thanks
ssmacae likes this.
AbdoBedir is offline   Reply With Quote
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 14:30
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
