Problem with NuT
Like Tree2Likes
  • 1 Post By fumiya
  • 1 Post By fumiya
Old   September 19, 2020, 14:44
Question Problem with NuT
MaySea is on a distinguished road
Hi, I am trying to simulate a turbulent PIMPLE flow. I am using OpenFoam6.
I am getting this error:
--> FOAM FATAL IO ERROR:
Essential entry 'value' missing
file: /home/jan/0/nut.boundaryField.barkley from line 52 to line 54
nut is defined like this:
| \\ / O peration | Version: 2.4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object nut;
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0;
boundaryField
south
type calculated;
value uniform 0;
east
type calculated;
value uniform 0;
watersurface
type slip;
north
type zeroGradient;
west
type zeroGradient;
barkley
type nutkRoughWallFunction;
Ks uniform 0.000755;
Cs uniform 0.5;
Does anyone have any idea?
Thanks,
Jan
MaySea is offline   Reply With Quote
Old   September 19, 2020, 22:08
DeadLee is on a distinguished road
I can't see it there but usually this error is due to a missing colon, a line that is commented out accidentally etc. Is it possible you're missing a parameter or two in barkley?
DeadLee is offline   Reply With Quote
Old   September 20, 2020, 02:34
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
The above message shows that value entry is missing in the following:
barkley
Cs uniform 0.5;
value uniform 0;
Hope this helps,
Fumiya
MaySea likes this.
[Personal]
fumiya is offline   Reply With Quote
Old   September 20, 2020, 13:23
Hi Fumiya,
Thanks I will try running it with the value entrance. I understood the error, what I don't understand is that the documentation doesn't say that value needs to be specified for this OF version. Only Ks and Cs
  Example of the boundary condition specification:
    \verbatim
    <patchName>
        Ks              uniform 0;
        Cs              uniform 0.5;
Old   September 22, 2020, 02:07
fumiya's Avatar
Fumiya Nozaki
Hi MaySea,
The value entry is necessary because the nutkRoughWallFunctionFvPatchScalarField class
is inherited from the fixedValueFvPatchScalarField class.
I understand that the value is only a place holder for nutkRoughWallFunction
and does not have any effect to simulation results.
Hope this helps,
Fumiya
MaySea likes this.
[Personal]
nut, nutilda, openfoam, pimple
Is COMSOL Multi Physics is suitable to solve complex flow problem? steve lee COMSOL 8 January 5, 2023 02:31
Mesh& steptime independant: conduction-convection problem Fati1 Main CFD Forum 1 October 28, 2018 13:52
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
