October 11, 2020, 13:40 |
S-shape Intake Diffuser : Boundary Condition
Rishabh Jaiswal
Rep Power: 5 |
https://www.cfd-online.com/Forums/at...1&d=1602436223
How to define BC for s-shaped duct intake at outlet ??? https://www.cfd-online.com/Forums/at...1&d=1602437017 CFD simulation for intake [s-shaped] which is connected to gas-turbine [in real condition] . It operates at different altitudes [Po & To varring with height]. [/B]but it is not able to define the proper boundary condition at the outlet of the intake.[/B] ................. tried with Pressure outlet (70120 Pa) condition is not appropriate because it does not match the practical condition ........ is their proper way of defining it [at the outlet side], which matches the practical condition at outlet ? Engine Details : m = 2.5 Kg/s [at ideal condition] {this much detail I know about gas turbine} at rpm = 4200 BC pressure far field : Ma = 0.5 , Po = 70120 Pa , To = 268.5 K Outlet BC ???????? [which is at AIP (Aerodynamic Interface Plane) as show in fig. ] Last edited by cfd.rishabh; October 12, 2020 at 09:29. |
November 21, 2020, 22:27 |
sam
Hi Rishabh:
At the AIP, the flow is subsonic, so the bc is going to be oinfluenced by both engine (downstream) and upstream (s-duct). As a first shot, you can impose a mass flow boundary condition at exit - thisis equivalent to prescribing an average exit static pressure at the AIP. HTH, Sam. |
Cyclic boundary condition in foam-extend 4.0 | rellumeister | OpenFOAM Pre-Processing | 2 | March 3, 2020 08:03 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 02:53 |
