Reason for Swril and Backflow in Fan Simulation
Old   July 2, 2020, 17:04
Default Reason for Swril and Backflow in Fan Simulation
kumar
Gkchpa is on a distinguished road
Hi everyone,
I am trying to Simulate fan in an enclosure of length 500 mm front & behind the fan.
incompressible Unsteady simulations
boundary conditions: Pressure Inlet and Pressure outlet - 0 gauge pressure (default)
Cell zone conditions: Rotating fluid domain with 3000 Rpm
as the Continuity is diverging I reduced relaxation factor momentum to 0.4 and KE to 0.4
run simulation for 150 iterations
So in the pathlines of flow, I can see the swirl and backflow. as I am new to fan Simulation I have no idea whether they are common in the simulation. If they arent how to solve them in the simulation
Thanks in advance
Gkchpa is offline   Reply With Quote
Old   July 4, 2020, 11:38
CFDfan is on a distinguished road
try with extended 2x, 3x, 4x computational domain
CFDfan is offline   Reply With Quote
Old   November 14, 2020, 17:28
Kira
aero_head is on a distinguished road
Backflow is occurring because your domain is not long enough. Try modifying that parameter.
aero_head is offline   Reply With Quote
Old   November 17, 2020, 07:40
Sascha
SaschaGH is on a distinguished road
swirl and backflow are common behind the fan.
Indeed extending your outlet section will help to avoid problems related to backflow, as you are providing more computational domain for the flow to settle, but you can also switch from "Outlet" to "Opening" definition, which will allow backflow.
SaschaGH is offline   Reply With Quote
Convergence and backflow problem in cavitation simulation burakaltintas CONVERGE 2 August 9, 2016 07:42
Constant Power Fan Model using General Momentum Source Dano62 CFX 0 April 14, 2016 13:09
Backflow at outlet in a Eulerian gas-solid simulation audrey CFX 10 October 25, 2012 06:15
Backflow in eulerian multiphase simulation xeusater FLUENT 0 June 26, 2009 07:50
backflow in a jet simulation Hao CFX 0 October 3, 2008 02:23
