Law of the wall with y+ < 5
Like Tree2Likes
  • 1 Post By sbaffini
Old   December 2, 2020, 15:17
Default Law of the wall with y+ < 5
SuperSonicCat is on a distinguished road
Hello forum,
very often i read the following statement: If a wall function is used, the first wall adjacent node should be in range 30 <y+<300.
I understand that in that range the logarithmic law of the wall holds. But what if the wall functions (e.g. in Ansys, LS-Dyna ICFD) are implemented such that for y+ < 11.225 linear law of the wall (u+=y+) is applied? Am i allowed to place the first node in the viscous sublayer and will i get good results?
If its not recommended to do so, why is the switching between linear and log- layer is implemented in above mentioned solvers?
Best regeards : )
SuperSonicCat is offline   Reply With Quote
Old   December 2, 2020, 16:15
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by SuperSonicCat View Post
Hello forum,
Best regeards : )
I think that the question can be reversed... If you can use a grid resolution fine until to resolve the viscous sub-layer, why do you want to use wall-modelled BCs?
FMDenaro is offline   Reply With Quote
Old   December 2, 2020, 16:54
Unfortunately, i have to use wall functions in LS-Dyna ICFD.
Old   December 3, 2020, 07:29
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
A wall function is always made of two pieces, the velocity (and other scalars) part and the turbulence model part. If a turbulence model can't be solved to low y+ then even having a linear log law won't help by itself.
But let's assume that the turbulence model can be solved to low y+ (Spalart Allmaras and k-omega models can). In this case you will have a single, approximate, near wall behaviour of the wall function to be matched with typically different behaviors of the different models. While you can adapt the constants of the law to each model, the fit will never be perfect (log linear is also very crude indeed). In this case you are probably safe to either work in full log or full linear, but don't expect great results in the buffer region.
There are exceptions. For example, the SA model allows for an exact wall function solution (which can be made the Musker profile with a simple modification to the model and also extended to other scalars).
So, in the end, it mostly depends from the model you are using, how is your software coded, what effort was put in it for certain cases, etc. But having a linear part, per se, doesn't solve that much.
SuperSonicCat likes this.
sbaffini is offline   Reply With Quote
Old   December 3, 2020, 08:25
Thank you for the answer.
Can the k-omega-model always be used for low y+ ? In the book of Wilcox "Turbulence modelling for cfd" i have read that there exist two versions of that model: Low- and High- Re- models.
Old   December 3, 2020, 08:29
sbaffini's Avatar
Paolo Lampitella
In practice, yes, it can be used both with and without that modification. But, as I said, the way a model is implemented (thus, the code) is key.
law of the wall, yplus
Wall treatment with OpenFOAM roby OpenFOAM Running, Solving & CFD 48 May 28, 2021 11:38
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Centrifugal fan j0hnny CFX 13 October 1, 2019 13:55
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 06:23
Wall Function Approach - log law Paul CFX 2 June 30, 2005 06:06
