[BlockMesh] Problem with blockMesh internal faces
Old   January 20, 2021, 06:10
Default [BlockMesh] Problem with blockMesh internal faces
parth
parthigcar is on a distinguished road
Dear all,
I am new to OpenFOAM. My blockMeshDict is looking as follows:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
scale 1;
rin  2.09;
rout 2.1;
h0 0;
h1 1.8;
delh 1.0005;
sin30 0.5;
cos30 0.866;
cos0 1;
sin0 0;
dr1 0.01;
dr2 0.06;
  //  (#calc "$rin*$cos30" #calc "$rin*-$sin30" $h0) //0
  //  (#calc "$rout*$cos30" #calc "$rout*-$sin30" $h0) //1
  //  (#calc "$rout*$cos30" #calc "$rout*$sin30" $h0) //2
  //  (#calc "$rin*$cos30" #calc "$rin*$sin30" $h0) //3
vertices
    (#calc "$rin*$cos30" #calc "$rin*-$sin30" $h1) //4
    (#calc "$rout*$cos30" #calc "$rout*-$sin30" $h1) //5
    (#calc "$rout*$cos30" #calc "$rout*$sin30" $h1) //6
    (#calc "$rin*$cos30" #calc "$rin*$sin30" $h1) //7
    (#calc "$rin*$cos30" #calc "$rin*-$sin30" $h1) //8
    (#calc "$rout*$cos30" #calc "$rout*-$sin30" $h1) //9
    (#calc "$rout*$cos30" #calc "$rout*$sin30" $h1) //10
    (#calc "$rin*$cos30" #calc "$rin*$sin30" $h1) //11
    (#calc "$rin*$cos30" #calc "$rin*-$sin30" #calc "$h1+$delh") //12
    (#calc "$rout*$cos30" #calc "$rout*-$sin30" #calc "$h1+$delh") //13
    (#calc "$rout*$cos30" #calc "$rout*$sin30" #calc "$h1+$delh") //14
    (#calc "$rin*$cos30" #calc "$rin*$sin30" #calc "$h1+$delh") //15
    (#calc "($rin+$dr1)*$cos30" #calc "($rin+$dr1)*-$sin30" $h1) //16
    (#calc "($rout+$dr2)*$cos30" #calc "($rout+$dr2)*-$sin30" $h1) //17
    (#calc "($rout+$dr2)*$cos30" #calc "($rout+$dr2)*$sin30" $h1) //18
    (#calc "($rin+$dr1)*$cos30" #calc "($rin+$dr1)*$sin30" $h1) //19
    (#calc "($rin+$dr1)*$cos30" #calc "($rin+$dr1)*-$sin30" #calc "$h1+$delh") //20
    (#calc "($rout+$dr2)*$cos30" #calc "($rout+$dr2)*-$sin30" #calc "$h1+$delh") //21
    (#calc "($rout+$dr2)*$cos30" #calc "($rout+$dr2)*$sin30" #calc "$h1+$delh") //22
    (#calc "($rin+$dr1)*$cos30" #calc "($rin+$dr1)*$sin30" #calc "$h1+$delh") //23
blocks
hex (0 1 2 3 4 5 6 7) (  30    300    300)  simpleGrading (1 1 1)   // bird
hex (8 9 10 11 12 13 14 15) (  30    300    20)  simpleGrading (1 1 1)    //beak
hex (16 17 18 19 20 21 22 23) (  70    300    10)  simpleGrading (3 1 1)    //beak
edges
  arc 0 3 ($rin 0 $h0)
  arc 1 2 ($rout 0 $h0)
  arc 4 7 ($rin 0 $h1)
  arc 5 6 ($rout 0 $h1)
  arc 8 11 ($rin 0 #calc "$h1")
  arc 9 10 ($rout 0 #calc "$h1")
  arc 12 15 ($rin 0 #calc "$h1+$delh")
  arc 13 14 ($rout 0 #calc "$h1+$delh")
  arc 16 19 (#calc "$rin+$dr1" 0 #calc "$h1")
  arc 17 18 (#calc "$rout+$dr2" 0 #calc "$h1")
  arc 20 23 (#calc "$rin+$dr1" 0 #calc "$h1+$delh")
  arc 21 22 (#calc "$rout+$dr2" 0 #calc "$h1+$delh")
boundary
    inlet
        type patch;
       faces
            (0 3 2 1)
    walls
        type wall;
       faces
            (7 3 0 4)
            (12 15 11 8)
            (2 6 5 1)
    wedge1
        type symmetry;
       faces
            (5 4 0 1)
            (8 9 13 12)
            (16 17 21 20)
    wedge2
        type symmetry;
       faces
            (3 7 6 2)
            (15 14 10 11)
            (23 22 18 19)
    top_walls
        type wall;
       faces
            (16 19 18 17)
            (12 13 14 15)
            (20 21 22 23)
    outlet
        type patch;
       faces
            (21 17 18 22)
    defaultFaces
        type empty;
        faces
            (4 5 6 7)
            (8 9 10 11)
            (23 20 16 19)
            (14 13 9 10)
mergePatchPairs
It generates some internal faces which blocks the flow during simulation.
Is my blockMesh is correct?
parthigcar is offline   Reply With Quote
blockmesh, blockmeshdict, internal faces
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 18:32
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 08:26
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
[snappyHexMesh] layer not added Rasmusiwersen OpenFOAM Meshing & Mesh Conversion 1 January 2, 2020 09:43
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
