January 11, 2021, 08:57 |
Standards in external gear pump design
Vivek MJ
Rep Power: 5 |
Hello all,
i am trying to reproduce a journal paper where the author has taken an external gear pump used in fighter aircraft. However, i do not access to all the dimensions of the gear pump casing. I would like to know if there is a design standard for gear pump casing which i can refer to so that i can model the gear pump casing. Any help will be appreciated greatly. I will put the link of the journal paper for reference. https://www.sciencedirect.com/scienc...59431117314990 |
design standard, gear pump, immersed body solver |
Setting up 3D simulation for external gear pump | 310toumad | FLUENT | 2 | February 5, 2019 09:12 |
External Gear Pump - CEL expression query | Kummi | CFX | 2 | August 1, 2018 20:39 |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
External Gear Pump | interawe | ANSYS Meshing & Geometry | 0 | April 14, 2009 17:55 |
3D External Gear Pump | Mustafa Ayad | FLUENT | 1 | January 26, 2009 09:55 |
