February 5, 2021, 10:10 |
Relaxation factor in transient problems
Hector Redal
Rep Power: 16 |
I would like to raise the following question from my side: Does relaxation factor apply in transient problems? I am currently studying the CBS algorithm for transient problem in fluids: https://onlinelibrary.wiley.com/doi/...3E3.0.CO%3B2-7 The algorithm uses two factors: theta1 and theta2. They are used in the follwoing manner: Velocity: V(t=n+theta1) = V(t=n) * (1-theta1) + V(t=n+1) * theta1 Pressure: P(t=n+theta2) = P(t=n) * (1-theta2) + P(t=n+1) * theta2 Which value of theta1 and theta2 should I use for transient problems? Is there any recommended value? Can these parameters be considered "relaxation factors"? Thanks for your kind support. Best regards Hector |
February 5, 2021, 12:28 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
If I understand, this form is generally related to an implicit class of time integration, for theta=1/2 the well known Crank-Nicolson time integration resulting in the scheme. It is a second order accurate quadrature formula for the time integral. |
February 5, 2021, 17:25 |
#3 | |
Hector Redal
Rep Power: 16 |
I understand it now. Thanks for your clarification. |
February 8, 2021, 12:03 |
Hector Redal
Rep Power: 16 |
One question from my side: If I understand it correctly, this means tha the error for the Crank-Nicolson scheme would be in the order of c * (delta T)^3. How big is that c, constant? My understanding is that this c would be in the order of the third derivate, right? Now, I would like to comment that I am using different schemes in my simulation (Backward Euler, forward Euler and Crank-Nicolson), but I do not see much difference in the simulation. Additionally, I am reducing a lot the delta T for the simulation, and the results does not change. This is puzzling me a bit. Best regards, Hector. |
February 8, 2021, 15:37 |
#5 | |
Rep Power: 71 |
No, the CN scheme is second order accurate, is not a third order scheme. You can easily see the local truncation error of the scheme by applying the trapezoidal rule to the time integral: Int [tn,tn+1] f dt - dt *[f(tn)+f(tn+1)]/2 = LTE |
Lets talk about relaxation factor optimization | chriss85 | OpenFOAM Running, Solving & CFD | 35 | June 21, 2019 09:54 |
Transient or Transient Blade Row? | liucheng8602 | CFX | 2 | June 19, 2014 07:03 |
max iterations in transient problems | vinse | FLUENT | 0 | November 7, 2007 05:10 |
Transient simulation and sliding mesh problems | alige | FLUENT | 0 | May 8, 2006 03:51 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
