Residuals not converging, but staying stable and fluctuating |
February 26, 2021, 04:19 |
Ash
Rep Power: 5 |
I am doing a hypersonic flow simulation on re-entry spacecraft, and for some reason, my residuals don't converge but rather stay stable for a while and then fluctuate (attached is a picture of it). I understand that the fluctuations could be decreased using relaxation factors, but could someone explain to me why the continuity and other variables aren't converging, as I would expect some sort of convergence after Would it be something to do with the mesh or initial BCS Thanks Residual 1.JPG Residual 2.JPG Residual 3.JPG |
February 26, 2021, 06:26 |
Sayan Bhattacharjee
Rep Power: 8 |
Do you have a fluctuating von-karman vortex street in the wake region?
Transient phenomenons cause fluctuations in residuals. You can run the simulations more 10000 iterations *here*, and see if the residuals converge or keep fluctuating. If they keep fluctuating but don't diverge, the solution might be okay. |
March 3, 2021, 02:48 |
Ash
Rep Power: 5 |
Ah I see thank you. I do notice Von-Karman Vortex sheets, and the results do look quite similar to the expected values. I have noticed though that my meshing is quite inconsistent, on of the blocks in a multi block grid. Do you think thatwould also have an effect?
March 3, 2021, 11:40 |
#4 | |
Kira
Rep Power: 8 |
Could you post a photo of the 'inconsistent' meshing? |
March 3, 2021, 15:13 |
Ash
Rep Power: 5 |
Sure, I've attached some photos of the mesh. For some reason, Ansys won't let me use the edge sizing for one block of my grid, and I can't seem to find out why.
Fluctuating residuals for all the parameters | jhssyb | FLUENT | 0 | January 7, 2016 21:12 |
