February 21, 2021, 20:36 |
ANSYS fluent and OpenFoAM comparison
Anonymous.
Rep Power: 5 |
Hi I was comparing ANSYS fluent and OPEN FOAM as a solver recently and was wondering what are the hardcoded difference between them that cannot be changed.
I am running a simple case from CFDNINJA with the same settings in Openfoam. I notice both use a different linear solver where Ansys is using AMG(algebraic Multigrid) while Openfoam is using Conjugate gradient solver. (I can change it to GAMG but I have yet to understand fully how AMG's algorithm work.) I was also wondering why the following occurs where the console ouput for ANSYS fluent is different from Openfoam where the fluent iterates all equation at the same time until all equation satisfy the residual but openfoam iterates one equations by one equations (I.e. Velocity equation then temperature equation). Console output of ANSYS fluent: Ansys fluent console output.png Console output of Openfoam: Openfoam console output.png ------------------------------------------------------------------------------------- Do linear solvers affect the output of a cfd simulation? i.e. oscillation occurs for OF but not ANSYS in my simulation when I use a turbulence model with exactly the same input. Setup for ANSYS fluent: Realizable K-e Standard wall function Transient, PISO algorithm Energy equation: on No gravity Fluid Material: Ansys database, Water(h20) liquid Linear Solver: AMG (Other settings were left at default) Setup for Openfoam: Solver used: BuoyantBoussinesqPimpleFOAM Realizable K-e Standard Wall function Pimple converted to PISO algorithm. Temperature equation on. No gravity Fluid material same as ANSYS. Linear solver: Conjugate gradient based. (Othersettings were set to be the same as ANsys fluent as shown in the attachmend below) Geometry 2D mixing elbow case from CFD NINJA : https://www.youtube.com/watch?v=Pjee...NJA%2FANSYSCFD My input files for OpenFOAM are attached here: https://entuedu-my.sharepoint.com/:f...Xvv7Q?e=S2U6vD Ansys fluent settings: https://entuedu-my.sharepoint.com/:f...mkTgw?e=dQWWPg I am at lost as I have been working on getting similar results but my Openfoam simulation kept oscilliating. |
[Other] [Request] OpenFOAM mesh to 2D Ansys fluent mesh | anon_q | OpenFOAM Community Contributions | 6 | July 3, 2023 05:24 |
OpenFOAM vs ANSYS Fluent (Solution and Schemes) | gentodin | OpenFOAM Programming & Development | 2 | February 21, 2021 20:56 |
Comparison between OpenFoam and Fluent results | chku24 | OpenFOAM Running, Solving & CFD | 2 | January 19, 2020 19:52 |
Comparison between OpenFOAM and FLUENT: capabilities | Time4Tea | OpenFOAM | 2 | November 5, 2018 13:11 |
How to export Ansys Fluent results to OpenFOAM? | anon_q | OpenFOAM | 1 | April 5, 2018 07:25 |
