How to calculate the coefficient for the turbulent viscosity |
April 2, 2021, 15:10 |
Turbulence
Rep Power: 5 |
Hello guys,
I am new to turbulence modeling and I have been stuck on this problem for weeks. Please help me! So I am trying to derive the k-equation in the log layer then calculate the coefficient C for the eddy viscosity vt in the form of vt=C⋅k^1/2⋅lmix. I have read the Wilcox textbook a hundred times and tons of other papers but I still have no clue how to solve for this coefficient. Does anyone know how the k-equation in the log layer looks like and how you solve for the coefficient for the eddy viscosity? Best, |
April 3, 2021, 08:12 |
I haven't understood what are you looking for exactly, but two of the most relevant sources on wall functions (and log layer by consequence) are the following two:
https://citeseerx.ist.psu.edu/viewdo...=rep1&type=pdf http://www.tfd.chalmers.se/~lada/pos..._report_WF.pdf Have you already looked at them for an answer? |
April 3, 2021, 15:14 |
#3 | |
Turbulence
Rep Power: 5 |
1:I am trying to derive the k-equation in the log-law region of a wall-bounded flow. So I used log layer assumptions. I assumed steady and fully turbulent, neglected both initial and molecular stresses, I think these are appropriate assumptions. However, I am not sure whether the turbulence kinetic energy k should be assumed to be a constant? In other two-equation models in log layer, k=ut^2/β^1/2=constant. 2: By dimensional analysis, the eddy viscosity originally has the form of Vt=Ck^1/2lmix, but in all references, they just use the constant C=1, so I am trying to figure out why C=1 or the expression for constant C. I hope that clears my questions. Thank. |
Density correction function for turbulent viscosity | Bando | STAR-CCM+ | 1 | July 9, 2017 02:44 |
How to calculate the gradient of turbulent viscosity ? | meishuojun | Fluent UDF and Scheme Programming | 2 | March 2, 2017 08:21 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
effective? turbulent? laminar? viscosity | MIssNancy | FLUENT | 3 | December 2, 2002 23:53 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
