Wall functions in DES for laminar boundary layers |
April 15, 2021, 18:22 |
Icaro Amorim de Carvalho
Rep Power: 5 |
I am simulating the flow over a circular cylinder at Re=10000 using DES with the Spalart-Allmaras model in the RANS part. I was running the simulation without wall functions and my y+<1 in the periodic regime (after many shedding cycles). But now I realise that the boundary-layer is laminar according to experiments in the literature. Should I use some wall function for this? Because, as I understand, DES will model the boundary-layer as turbulent by using RANS there. If references could be provided for this, I would highly appreciate as well. Thanks. Last edited by PenPencil; April 15, 2021 at 21:17. Reason: Addition of relevant information |
April 16, 2021, 03:28 |
A wall function is, in a sense, a surrogate for a turbulence model in the near wall region when you have not enough points to describe the near wall profile. So, no, you don't use it for a laminar flow.
In DES, the near wall RANS part is actually there as a form of wall function for the outer LES part. So, doesn't really make sense to use a wall function in a DES (yet, it is certainly acceptable or required to still have it in place for when y+ fluctuates above a certain critical value). Typically, you either go DES or LES with wall functions (however, there are areas where one is reccomended over the other, of course). Thus, what you are looking for is just pure LES with some model that will deactivate itself in laminar regions. Dynamic ones will do it, but there are alternatives. |
April 17, 2021, 13:04 |
#3 | ||
Rep Power: 5 |
Dear Paolo,
thank you for your input. Quote:
I just found a paper related to this. It seems like this thought was followed here for the same Reynolds number https://onepetro.org/IJOPE/article-a...dFrom=fulltext. The author tightly met experimental results. Quote:
EDIT: Paolo, my mistake, you are right. After thinking over what you said, I have looked into OpenFOAM's documentation and found that in Spalart-Allmara's DES formulation a correction for low-Re is already present. Sorry for my incorrect understanding and thank you once again. Last edited by PenPencil; April 17, 2021 at 23:11. |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
