May 24, 2021, 04:59 |
Problem with Prandtl-Meyer expansion wave
Cao Khánh Tân
This problem will solve for the flow over the expansion corner (Prandtl-Meyer expansion wave) with conditions:
- Freestream Pressure: P0 = 100000Pa - Freestream Temperature: T0 = 286K - Velocity: U0 = 100m/s - Wedge angle: alpha = 5.325^o The configuration of the wedge shows as below. Do the simulation of inviscid flow using the sample code based on explicit Maccormack’s technique: Problem 1. Generate the structure grid (100 x 30), with the grid point distribution as shown in figure? What does the method you use? Explain the grid behavior in order to have the reasonable accurate? Problem 2. Do the simulation: - Explain the boundary condition? - Is the artificial viscosity applied? Why? - Plot data of Mach number, pressure, density, velocity? Compare with the analysis data? Hello, i have a midterm test with cfd and i have some problems. So i need help. I solved problem 1. And i can't explain question 2 in Problem 2 |
[waves2Foam] irregular wave problem | yangzhou | OpenFOAM Community Contributions | 0 | July 19, 2017 08:42 |
wave pattern problem running LTSInterFoam | Alex song | OpenFOAM Running, Solving & CFD | 2 | May 10, 2015 03:14 |
DFBI: Wave profile with pitching problem?! | fuzel | STAR-CCM+ | 7 | July 21, 2012 04:52 |
Problem Concerning free surface wave simulation | michaels | STAR-CCM+ | 3 | February 25, 2011 07:28 |
Prandtl-Meyer Expansion Wave | Maciej Matyka | Main CFD Forum | 0 | March 13, 2003 19:55 |
