June 6, 2021, 07:28 |
shocks and expansion fans
Khemraj Gautam
Can we use isentropic relation across compression waves near compression corner? If yes, how compression waves result to non isentropic shock? If No, why?
June 6, 2021, 11:09 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
If you are talking about steady flows, the shock waves are not isoentropic. However, if you have a look to the Zucrow's textbook, you will find the omoentropic compression flow produced by a piston moving in a cylinder. This model is valid until the compression waves produce a singularity by coalescence. |
June 7, 2021, 02:35 |
Sayan Bhattacharjee
Rep Power: 8 |
Shockwaves are non-isentropic, as the process is irreversible, hence the entropy of the entire system decreases. However, the total enthalpy remains constant. Cool stuff, shockwaves.
https://www.grc.nasa.gov/WWW/k-12/airplane/oblique.html |
Euler equations & expansion shocks | technophobe | Main CFD Forum | 5 | April 28, 2009 15:11 |
Physical origins of shocks? | Dave | Main CFD Forum | 24 | August 1, 2008 04:09 |
Difference between shock and expansion wave? | jinwon park | Main CFD Forum | 2 | May 6, 2008 04:06 |
Boundary Layer created by Euler Solvers | Jim | Main CFD Forum | 31 | November 17, 2001 23:18 |
