Heat Transfer in OpenFoam
Like Tree2Likes
  • 1 Post By piu58
  • 1 Post By AshwaniAssam
Old   July 13, 2021, 11:00
Default Heat Transfer in OpenFoam
hityo is on a distinguished road
I want to learn Heat Transfer Simulation in OpenFoam. So what is the advice and from where should i start?
plus I'm not so strong in Thermodynamic
hityo is offline   Reply With Quote
Old   July 13, 2021, 12:34
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
I assume that you want to know the heat transfer form some kind of boundary layer.
I recommend simulating only the fluid stream. From this you get the local thickness of the Prandtl layer at the boundary. From this you may calculate the Nernst layer which is connected to the local heat transfer rate.
You may compere your results with the ones which the Nußelt number give. And you will find how hard is is to get the thin Prandl layer at regions with high stream velocity.
hityo likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   July 14, 2021, 04:09
Ashwani
AshwaniAssam is on a distinguished road
https://www.openfoam.com/documentati...andard-solvers
Start with the heat transfer solver which suits your need. You can start with the tutorials pertaining to that solver.
hityo likes this.
AshwaniAssam is offline   Reply With Quote
cfd - post, fluid mechanics, openfom, thermodynamics
Current state of conjugate heat transfer in OpenFOAM Dreoasteh OpenFOAM 2 April 4, 2023 13:47
Coupled Heat and Mass Transfer Mecroob OpenFOAM Running, Solving & CFD 1 July 12, 2020 19:24
Flow around heatsink with heat transfer S Mughal FLUENT 0 April 13, 2018 13:06
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 05:07
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
