0D and 1D numerical modeling
Like Tree2Likes
  • 1 Post By piu58
  • 1 Post By sbaffini
Old   August 6, 2021, 16:56
Default 0D and 1D numerical modeling
abdessamad
Nnoxis is on a distinguished road
Hello everyone.
I am looking for definitions or specific informations on 0D and 1D numerical modeling and examples of applications.
Also a comparison with 3D CFD numerical modeling.
And thank you very much for your support.
Nnoxis is offline   Reply With Quote
Old   August 7, 2021, 03:13
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
I don't think that is a thing like 0D fluid dynamics. Fluid means flow, and flow needs a direction.
0D simulation may be calculations of chemical equilibrium or so.
There may be applications for 1D fluid dynamics. That means that the flow has changes only in one direction. Such simple cases often don't need a numerical simulation and can be examined with pure mathematics. Often, you have some kind of coordinate transformation here, e.g. form spherical coordinates to 1D.
Nnoxis likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   August 7, 2021, 04:49
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
As the terms imply, they refer to problem formalizations that lack several or all of their spatial extensions. These can be used when the problem indeed has very small variations in the neglected dimensions, but also when more dimensions are not computationally affordable and the missing dimensions are accounted for by some model/trick.
A 0D description lacks any spatial extension, thus it either is an algebraic equilibrium relation or an unsteady evolution equation (a time dependent ODE). Chemical reactions (or their fast chemistry approximation) are, as mentioned, a good example. But you also see them in system level codes, where maybe a whole pump is modeled in this way.
A 1D model instead only retains one significant spatial dimension in some problem description. Imagine flows in long pipes, or human blood flow. But, again, system level codes will necessarily use such 1D descriptions even when not applicable (e.g., a short pipe between two large 0D sub-systems).
Nnoxis likes this.
sbaffini is offline   Reply With Quote
Old   August 7, 2021, 16:03
abdessamad
Thank you all for your support.
