August 10, 2021, 03:03 |
Simulation of a 2D diffuser
Rep Power: 4 |
Hi CFD users, for my CFD cource at the university I have to simulate flow into a 2D diffuser. Section of the diffuser is reptangular. Fluid can be treated as incompressibile. As a data, I know only Reynolds number based on hydraulic diameter, at the outlet, and the exit of the diffuser is at the atmosferic pressure. I calculate the mean velocity at the outlet using the Reynolds number given me as a data, and then the mass flow rate.
As boundary conditions, since I know nothing about the inlet, I calculate the velocity at the inlet based on the mass flow rate,because the fluid can be treated as incompressibile. Then I imposed velocity inlet as a boundary condition at the inlet, and pressure outlet(gauge pressure equal to zero) at as boundary condition at the outlet. I simulate the flow for two different Reynolds numbers: 50 and 8200. However, a strange thing appears: in both cases I have flow separation, but the reattach point in case Re=8200(turbulent flow) is much more far away from the diffuser outlet than in case Re=50 (laminar flow). Is something wrong with my boundary condition? Someone can help me? Is very important Last edited by Sam6789; August 10, 2021 at 06:03. |
August 10, 2021, 11:35 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
If you say "strange thing" I immagine you already know the solution of your flow problem. What references are you using? Owing to the 2D model, you are using for sure a RANS formulation, your solution is therefore strongly dependendent on the model parameters. |
August 10, 2021, 13:32 |
#3 | |
Rep Power: 4 |
I'm using a k-omega SST model |
August 10, 2021, 13:38 |
Rep Power: 71 |
Have you ever studied the test case of the backward facing step in laminar and turbulent regimes?
August 10, 2021, 13:50 |
Rep Power: 4 |
August 10, 2021, 17:01 |
Rep Power: 71 |
Several papers can be found by searching on internet, for example
https://www.google.com/url?sa=t&rct=...PFMiBHZkJQCi07 |
boundary condition, diffuser pipe flow, separate region |
Some questions about flow boiling simulation in Fluent | beastieboys6 | FLUENT | 8 | November 20, 2017 23:47 |
Confirmation of a simulation in a diffuser. RANS flow, sticks to the wall. | wannab_phd | OpenFOAM Verification & Validation | 0 | October 24, 2016 11:49 |
Control simulation to apply different fields with chtMultiRegionFoam | jmdf | OpenFOAM Running, Solving & CFD | 0 | February 29, 2016 07:05 |
centrifugal compressor-diffuser simulation : Overflow | insisivus | CFX | 7 | April 22, 2014 06:41 |
Convergence of jet flow simulation | MiraLisa | FLUENT | 0 | August 15, 2013 04:44 |
