Pointwise Mesh and Block Regarding Turbomachinery case
Like Tree1Likes
  • 1 Post By t.teschner
Old   August 19, 2021, 04:15
Default Pointwise Mesh and Block Regarding Turbomachinery case
Wang Li
Hanvo is on a distinguished road
Hi ,is there anyone who is familiar with POINTWISE to generate block for rotating impeller in case of radial Pump.
here is example in given picture
Hanvo is offline   Reply With Quote
Old   August 19, 2021, 16:19
Tom-Robin Teschner
t.teschner is on a distinguished road
Normally I would suggest using the customer support for these sort of questions which are really helpful but I guess this is not an option for you since your customer ID is SolidSQUAD?!
AtoHM likes this.
t.teschner is offline   Reply With Quote
Old   August 20, 2021, 02:12
Wang Li
Ok thanks for you suggestions.
ponitwise, pump simulation, turbomachines
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 05:02
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets Struggle_Achieve OpenFOAM Meshing & Mesh Conversion 3 June 17, 2019 09:29
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[blockMesh] Mixer mesh - negative volume problem jadtwo OpenFOAM Meshing & Mesh Conversion 2 November 6, 2014 16:37
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 02:58
